Hi Joern,
Assuming that the wrong software got install first, you will need to fully uninstall Mira and install this version: Mira+ 9.3.1
You also need to make sure that you have the correct license to run this version. As Marsha mentioned, I would also recommend you contact Tech Support. They will be able to help you with that. The toll free number is: +1 833-859-0499
Isabelle Berthiaume
Demo Artist and Trainer - Video Servers Product Prime
Montreal Canada
Sent: 09-20-2024 02:09
Subject: Update from Mira+ 9.0.1 to 9.3.1 doesn't work
That was the upgrade path I used. Began the installation, the update was running. Then I got the Error massage, this is a Mira Update it doesn't run on Mira+ systems. What's going wrong.
Joern Steiwer
STEIWER TV
Sent: 09-19-2024 15:56
Hi Joern, there's a difference between Mira and Mira+ software. Mira software cannot be put on a Mira+. You need to download and install Mira+ software. https://www.rossvideo.com/support/software-downloads/mira-plus-software-downloads/
Marsha Opacic
Manager, Training Solutions - Sports & Graphics
United States
