Hi Daniel,
It will be in Ultrix User Guide manual for Ultrix/Ultricore 6.6.0 release (manual v28-rev8), searches for keywords "RossTalk Commands" to locate information about RossTalk.
Phu Nguyen
UI & Workflow Manager
Sent: 07-22-2025 17:14
Subject: Updating Ultriscape Clock with data from an outside source
Thank you Phu,
The TIMER ##:SET command worked perfectly.
I cannot seem to locate the SET command in the Ultrix or Ultrix/Acuity manuals. Can you point me to the specific place you're referencing?
Daniel Elliott
Sent: 07-16-2025 10:15
Hi Daniel,
In Ultrix User Guide manual, searches for keywords "RossTalk Commands" to locate information about RossTalk.
RossTalk Commands:
GPI ##
TIMER ##:RUN
TIMER ##:STOP
TIMER ##:PAUSE
TIMER ##:END
TIMER ##:SET:hh:mm:ss.s
Phu Nguyen
