I assume you are running Ross hardware, what version?
I had issues with drivers for the RAID when upgrading to Windows 10 on our V5 machine. Not sure if it was made easier or harder by us doing a fresh install of Windows 10 on an SSD separate from the RAID, but getting it working required letting windows fail to boot, turning the machine off, disconnecting the RAID card, booting up windows, getting the correct driver installed, turning the system off, and reconnecting the RAID card... Obviously can't do that if you are trying to upgrade Windows 10 on the RAID. Maybe you need to preemptively update the RAID driver before you start the Win10 install?
David Krug
Production Manager
Open Signal: Portland Community Media Center
Portland United States
Sent: 05-19-2023 16:14
Subject: Upgrade Operating System
I have done that, twice, but I will give it another go.
The issue is every time I try it, and it fails, my system is then of no use and I have to clone again from my original back up which would you believe takes me 2 days.
It looks like it is downloading updates before the install even tho I have told it not to.
If it fails again I will post images of what occurs this time.
Sent: 5/19/2023 3:56:00 PM
Subject: RE: Upgrade Operating System
Try following this document.
