A quick a dirty way would be to use %relid%.
create a scene group and number it for example 1000, then put your scene in that group 1001, Datalinq your excel, but where it selects the row <1>, swap that with <%relid%>, then make as many copies as you want.
the last part, goto the group and change the Group Take option at the bottom. Play out Mode to Timed, then set it to Fixed Item Duration and set your time. Then in that section you can set it to loop or take offline at the last message.
Curtis MacDonald
