HI Kurt,
in my thought's might I am wrong and let me correct more. the thing you want is to get datalinq clock in panel grid. might that can be
achieved by dashboard services through which you can get parameters of devices.
hope any one else have handy hands on this.
[Wajahat] [Ali]
[Team Lead] [RTG Designer]
[Hum News][Karachi/Islamabad] [Pakistan]
Sent: 09-12-2024 19:27
Subject: Using Dashboard to Display Clock and Score Data
Hey Wajahat Ali,
I appreciate the reply. Unfortunately I want to go the other direction. The data already lives in Datalinq (it is already on the network via a UDP port), and I just want to display it using Dashboard, if possible. It is data that is already being generated from a scoreboard.
Any thoughts?
Kurt
Sent: 09-11-2024 14:52
for sample attaching file.
https://mega.nz/file/vtQBSDAa#tFcMAjqzDesMFCyvAKvNnoACe8SS07doqefn6hqh-1c
[Wajahat] [Ali]
Sent: 09-11-2024 14:13
Yes there is way. For this you have to use widget with label text in dash board through which you can send and expose clock parameter to datalinq.
You also have to setup streaming port of panel.
there is xpression u dashboard tut available.
[Wajahat] [Ali]
