  • 1.  Using symbolic links
    Posted 03-17-2024 09:52
    I added a shortcut to a folder in another folder with images. Under template data, tab Image Files, this shortcut to a folder wasn't visible.
    I found a solution to this, i removed the shortcut and created a Symbolic Link to that same folder instead (MKLINK /D ....) ...that appeared to work fine.
    I am not in any way some IT dude, so i wondered if anyone knows if this lkind of work around could cause any significant problems?
    Justus van der Hulst
    Live Graphics Operator
    Euro Media Group
    Hilversum, The Netherlands
  • 2.  RE: Using symbolic links
    Posted 03-25-2024 14:18
    Its totally fine to use Symbolic/Symlinks.
    was the shared folder a network drive?
    If it was a network share, and its not showing in the XPression file browser, you can fix that by making this change:
    In Registry Editor, locate and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
    Right-click Configuration, click New, and then click DWORD (32-bit) Value.
    Name the new registry entry as EnableLinkedConnections.
    Double-click the EnableLinkedConnections registry entry.
    In the Edit DWORD Value dialog box, type 1 in the Value data field, and then click OK.
    Exit Registry Editor, and then restart the computer.
  • 3.  RE: Using symbolic links
    Posted 03-25-2024 14:32
    Yep, the shared folder was a network drive, and it worked instantly .. but always good to know the fix in the registry if it wouldn't work.
    Euro Media Group
