After speaking with a colleague, we were able to build an ISO audio router using Dashboard. Maybe this will help someone else.
In Dashboard, in our database we added a Multibus panel. We did this on our Control room An Ultrix frame since all of our cameras were already there.
In our current destination table, we named 4 unused destinations as ISO Embedder 1 through 4. (These will be physical outputs to our Evertz router). We set the panel to 4 destinations and then added those destinations to that panel.
We then added all of the Camera sources we would need. On my Audio from Dante panel, in Dashboard, which is where I get my program feed from my audio board, I added enough new Dante feeds to match the number of Mics we use. For example, Mic 1, Mic 2, etc. Testing this on a pre-fader setup, we simply routed our mics to these new Dante receives. For the sources I did include 2 audio sources that are attached to the cam.
Now, all I have to do is choose the cam, and click take. Then I choose my two channels of audio, then click on the Mic channel and click take. This links them together.
We do need to test the final output but that said, this did seem to be a relatively easy solution to this issue.
Robert Kinnan
Broadcast Engineer
Spectrum Charter News
Sent: 10-09-2025 12:03
Subject: Using Ultrix Router to make a Custom Embedder
You could do this two ways...
On the output you would do a Video only Switch to the source you want and then do an Audio Only Switch to the Audio Source you would like.
Or
you create more "Inputs" in your table that have the additional Audio Variations... that way you could add the audio that you want with it...
ie
Cam 1 with "Camera Audio Channels"
Cam 1 with "PGM Audio Channels"
Cam 1 with "Effects Mics"
IN those cases you would switch the outputs via a combined source and all levels
