A material name will appear in the faces property of an object.
here I have tied it to a text object which would allow me to do pretty much whatever I want from there.
Sent: 10-05-2023 19:24
Subject: Using Visual Logic or Scripting to change position and width of text object
Is there a way to have whether the quad has a material or new material assigned to it control the text position, instead of the quad's visibility?
I have the length of text string control similar adjustments on other objects. (0 string length as opposed to 1 or greater)
Cindy McNicholl
Sent: 10-05-2023 17:51
Here is the file, attached the wrong one before...
Omar Reyes
Fargo United States
Sent: 10-05-2023 17:03
This can be done easily with the Input Selector in Visual Logic. The Visible node will show 0 (quad is hidden) or 1 (quad is visible), connect this to the Index of the Input Selector node to have it select which value to use for the Output. As for changing the bounding box for the text, you'll want to use the Autosqueeze Width node.
I'll attach the project I made and a screenshot below:
Omar Reyes
Fargo United States
