I'm sorry for that. You'll find the script below. Thank you for your attention.
<abs contexttype="opengear" style="bg-u:Images/Red.jpg;" virtualheight="1077" virtualwidth="1918">
<timer id="ClipName1" pattern="HH:mm:ss" rate="1000">
<timertask tasktype="ogscript">function callbackFunction1(success, cmd, result, exception)
if (success = 'true') {
ogscript.rename('clipName1',result); //Update Channel 1 Clip Name in playout area
params.setValue('Blackstorm.loadedClipName',0,result); //Store Channel 1 Clipname
params.setValue('Blackstorm.Channel1State', 0, 0); //Set Channel 1 State to none
var host = params.getValue('Blackstorm.IPAddress', 0); //Get IP Address
var port = params.getValue('Blackstorm.PortNumber', 0); //Get Port Number
var numOfChs = params.getValue('Blackstorm.NumOfChannels', 0); // Get the number of Channels
var state = params.getValue('Blackstorm.Channel1State', 0); //Get the the Channel 1 state flag
if (numOfChs > 0) {
if (state == 0) {
vdcp.activeClip(host,port, 1, callbackFunction1);
params.setValue('Blackstorm.Channel1State', 0, 1); //Set Channel 1 State to request
ogscript.debug('Channel 1Requesting');
}</timertask>
</timer>
<timer id="ClipName4" pattern="HH:mm:ss" rate="1000">
<timertask tasktype="ogscript">function callbackFunction4(success, cmd, result, exception)
ogscript.rename('clipName4',result); //Update Channel 4 Clip Name in playout area
params.setValue('Blackstorm.loadedClipName',3,result); //Store Channel 4 Clipname
params.setValue('Blackstorm.Channel4State', 0, 0); //Set Channel 4 State to none
var port = params.getValue('Blackstorm.PortNumber', 3); //Get Port Number
var state = params.getValue('Blackstorm.Channel4State', 0); //Get the the Channel 4 state flag
if (numOfChs > 3) {
if (state == 0) {
vdcp.activeClip(host,port, 4, callbackFunction4);
params.setValue('Blackstorm.Channel4State', 0, 1); //Set Channel 4 State to request
ogscript.debug('Channel 4 Requesting');
}</timertask>
</timer>
<timer id="ClipName3" pattern="HH:mm:ss" rate="1000">
<timertask tasktype="ogscript">function callbackFunction3(success, cmd, result, exception)
ogscript.rename('clipName3',result); //Update Channel 3 Clip Name in playout area
params.setValue('Blackstorm.loadedClipName',2,result); //Store Channel 3 Clipname
params.setValue('Blackstorm.Channel3State', 0, 0); //Set Channel 3 State to none
var port = params.getValue('Blackstorm.PortNumber', 2); //Get Port Number
var state = params.getValue('Blackstorm.Channel3State', 0); //Get the the Channel 3 state flag
if (numOfChs > 2) {
if (state == 0) {
vdcp.activeClip(host,port, 3, callbackFunction3);
params.setValue('Blackstorm.Channel3State', 0, 1); //Set Channel 3 State to request
ogscript.debug('Channel 3 Requesting');
}</timertask>
</timer>
<timer id="ClipName2" pattern="HH:mm:ss" rate="1000">
<timertask tasktype="ogscript">function callbackFunction2(success, cmd, result, exception)
ogscript.rename('clipName2',result); //Update Channel 2 Clip Name in playout area
params.setValue('Blackstorm.loadedClipName',1,result); //Store Channel 2 Clipname
params.setValue('Blackstorm.Channel2State', 0, 0); //Set Channel 2 State to none
var port = params.getValue('Blackstorm.PortNumber', 1); //Get Port Number
var state = params.getValue('Blackstorm.Channel2State', 0); //Get the the Channel 2 state flag
if (numOfChs > 1) {
if (state == 0) {
vdcp.activeClip(host,port, 2, callbackFunction2);
params.setValue('Blackstorm.Channel2State', 0, 1); //Set Channel 2 State to request
ogscript.debug('Channel 2 Requesting');
}</timertask>
</timer>
<meta>
<lookup code="true" id="GlobalScripts" multiline="true" name="Global Scripts">
<entry key="LoadClip">function loadClip(channel){
var ip = params.getValue('Blackstorm.IPAddress', 0); //Get IP Address
var port = params.getValue('Blackstorm.PortNumber', (channel - 1)); //Get Port Number
var fileExt = params.getValue('Flag.Extention', 0); //Get File extension flag
var extension = params.getValue('Blackstorm.extension', 0);
//Get the current selected line item in the displayed cliplist
var clip_index = params.getValue('Blackstorm.ClipList',0);
//Get the String name of the selected clip
var name = params.getIdentifiedConstraint('ClipListChoices').getStringOf(clip_index);
if (fileExt) {
name = name + extension;
//Update the currently selected clipname
params.setValue('Blackstorm.loadedClipName', (channel - 1), name);
ogscript.debug('Load Clip: '+name+' in to Channel: '+channel);
//Cue the selected clip into the selected Channel
function callbackFunction(success, cmd, result, exception)
if (success){
ogscript.rename('status'+channel, 'Clip Loaded');
vdcp.cueClip(ip, port, channel, name, callbackFunction);
}</entry>
<entry key="CueClip">function cueClip(channel){
var name = params.getValue('Blackstorm.loadedClipName', (channel - 1));
//Recue the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Cued');
ogscript.debug('Cue Clip: '+name+' in to Channel: '+channel);
}</entry>
<entry key="RewindClip">function revClip(channel){
//Rewind the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Rewinding');
vdcp.rewind(ip, port, channel, callbackFunction);
ogscript.debug('Rewind Channel: '+channel);
}</entry>
<entry key="StopClip">function stopClip(channel){
//Stop the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Ejected');
vdcp.stop(ip, port, channel, callbackFunction);
ogscript.debug('Stop Channel: '+channel);
}</entry>
<entry key="PlayClip">function playClip(channel){
//Play the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Playing');
vdcp.play(ip, port, channel, callbackFunction);
ogscript.debug('Play Channel: '+channel);
}</entry>
<entry key="PauseClip">function pauseClip(channel){
//Pause the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Paused');
vdcp.pause(ip, port, channel, callbackFunction);
ogscript.debug('Pause Channel: '+channel);
}</entry>
<entry key="FastForwardClip">function ffClip(channel){
//Fast Forward the current loaded clip.
if (success){
ogscript.rename('status'+channel, 'Clip Fast Forwarding');
vdcp.fastForward(ip, port, channel, callbackFunction);
ogscript.debug('Fast Forward Channel: '+channel);
}</entry>
</lookup>
<lookup id="hosts">
<entry key="BlackStorm.host">172.16.7.178</entry>
<entry key="BlackStorm.port">50103</entry>
<entry key="XPNBVS.host">10.0.200.91</entry>
<entry key="XPNBVS.port">50103</entry>
</lookup>
<constraint constrainttype="INT_CHOICE" id="ClipListChoices" precision="0">
<constraint key="0">Choices Not Loaded</constraint>
</constraint>
<params>
<param access="1" maxlength="0" name="IP Address" oid="Blackstorm.IPAddress" type="STRING" value="10.65.1.174" widget="0"/>
<param access="1" constrainttype="INT_CHOICE" name="Clip List" oid="Blackstorm.ClipList" precision="0" strvalue="List Not Loaded" type="INT32" value="690" widget="7">
<constraint key="0">List Not Loaded</constraint>
</param>
<param access="1" maxlength="0" name="Port Number" oid="Blackstorm.PortNumber" precision="0" type="STRING_ARRAY" widget="0">
<value>50103</value>
<value>50104</value>
<value>50105</value>
<value>50106</value>
</param>
<param access="1" maxlength="0" name="Clip Names" oid="Blackstorm.loadedClipName" precision="0" type="STRING_ARRAY" widget="0">
<value>WJR's Timeout</value>
<value>WJr's Post Replay</value>
<value>World Jrs Empty Net Post</value>
<value>World Jrs Empty Net Replay</value>
</param>
<param access="1" constrainttype="INT_CHOICE" name="File Extention" oid="Flag.Extention" precision="0" strvalue="OFF" type="INT16" value="0" widget="0">
<constraint key="0">OFF</constraint>
<constraint key="1">ON</constraint>
</param>
<param access="1" maxlength="0" name="Extension" oid="Blackstorm.extension" type="STRING" value=".mov" widget="0"/>
<param access="1" constrainttype="INT_CHOICE" name="Number of Channels" oid="Blackstorm.NumOfChannels" precision="0" strvalue="0" type="INT16" value="0" widget="0">
<constraint key="0">0</constraint>
<constraint key="1">1</constraint>
<constraint key="2">2</constraint>
<constraint key="3">3</constraint>
<constraint key="4">4</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="Channel 1 State" oid="Blackstorm.Channel1State" precision="0" type="INT16" value="0" widget="default">
<constraint key="0">None</constraint>
<constraint key="1">Request</constraint>
</param>
<param access="1" constrainttype="INT_CHOICE" name="Channel 2 State" oid="Blackstorm.Channel2State" precision="0" type="INT16" value="0" widget="default">
</param>
<param access="1" constrainttype="INT_CHOICE" name="Channel 3 State" oid="Blackstorm.Channel3State" precision="0" type="INT16" value="0" widget="default">
</param>
<param access="1" constrainttype="INT_CHOICE" name="Channel 4 State" oid="Blackstorm.Channel4State" precision="0" type="INT16" value="0" widget="default">
</param>
</params>
<style id="TitleLabel" name="TitleLabel" value="bdr#000000;size:20;bg#393939;"/>
<style id="ParamLabel" name="ParamLabel" value="size:Big;bg#dark;txt-align:center;bdr:etched;"/>
<ogscript handles="onchange" oid="Blackstorm.NumOfChannels">for (var i = 1; i < 5; i++)
ogscript.hide('Channel'+i);
if (numOfChs == 1){
ogscript.reveal('Channel1');
}else if (numOfChs == 2) {
ogscript.reveal('Channel2');
}else if (numOfChs == 3) {
ogscript.reveal('Channel3');
}else if (numOfChs == 4) {
ogscript.reveal('Channel4');
}</ogscript>
<ogscript handles="onload" name="Reset Channel States">params.setValue('Blackstorm.Channel1State', 0, 0);
</ogscript>
</meta>
<label height="84" left="717" name="DashBoard VDCP" right="727" style="size:30;bg#3E3C3C;font:bold;txt-align:center;bdr:etched;" top="11"/>
<abs height="962" left="15" style="bg#panelbg;bdr:etched;" top="101" virtualheight="962" virtualwidth="936" width="936">
<button buttontype="push" height="104" left="23" name="Load Clip List" top="198" width="886">
<task tasktype="ogscript">function myFunc(success, cmd, result, exception)
ogscript.debug("List Clips callback: " + success);
var list = params.createIntChoiceConstraint(result); //Create a choice constraint with the results of the clip list
params.replaceIdentifiedConstraint('ClipListChoices', list); //Replace the old list with the new clip list
ogscript.reload('ClipSelector'); //Refresh the Clip List display
//Get the cliplist from the server run 'myFunc'
vdcp.listClips(ip, port, myFunc);
ogscript.debug ("List Clips Sent. IP Address: " + ip);</task>
</button>
<table height="409" left="23" top="314" width="886">
<tr>
<label colspan="1" fill="both" height="35" insets="2,2,2,2" name="Clip List" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="0.2" width="545"/>
</tr>
<tr>
<param anchor="west" constraint="ClipListChoices" constrainttype="ID_REFERENCE" fill="both" height="277" id="ClipSelector" insets="2,2,2,2" oid="Blackstorm.ClipList" precision="0" scroll="vertical" showlabel="false" style="bdr:none;" weightx="1.0" weighty="1.0" widget="35" width="545"/>
</tr>
</table>
<table height="99" left="30" top="835" width="872">
<tr>
<button buttontype="push" colspan="1" fill="both" height="60" name="Load to Channel 1" rowspan="1" weightx="1.0" weighty="1.0" width="322">
<task tasktype="ogscript">%const['GlobalScripts']['LoadClip']%
loadClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="60" name="Load to Channel 2" rowspan="1" weightx="1.0" weighty="1.0" width="322">
loadClip(2);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="60" name="Load to Channel 3" rowspan="1" weightx="1.0" weighty="1.0" width="322">
loadClip(3);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="60" name="Load to Channel 4" rowspan="1" weightx="1.0" weighty="1.0" width="322">
loadClip(4);</task>
</button>
</tr>
</table>
<table height="92" left="684" top="733" width="210">
<tr>
<table colspan="1" fill="both" height="25" insets="2,2,2,2" name="" rowspan="1" style="txt-align:center;" weightx="1.0" weighty="1.0">
<tr>
<label colspan="1" fill="both" height="37" name="Add Extension:" rowspan="1" style="txt-align:west;" weightx="1.0" weighty="1.0" width="131"/>
<param colspan="1" element="0" fill="both" height="37" oid="Blackstorm.extension" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0" width="131"/>
</tr>
</table>
</tr>
<tr>
<param colspan="1" expand="true" fill="both" insets="2,2,2,2" oid="Flag.Extention" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<label height="99" html="true" left="36" scroll="vertical" style="bdr:shadow;" top="732" width="637"><![CDATA[
Some VDCP devices display clip lists without file extensions, but require them to load clips.
If needed type the file extension in the field to the left and select On.
The 'useFileExtensionVDCP' parameter on Blackstorm can be found C:\Ross\Blackstorm\ControllerPortsConfig.xml (default is set to false).
]]></label>
<table height="175" left="23" top="20" width="876">
<tr>
<label colspan="1" fill="both" height="57" insets="2,2,2,2" name="Number of Channels:" rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="424"/>
<param colspan="1" expand="true" fill="both" height="57" insets="2,2,2,2" oid="Blackstorm.NumOfChannels" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0" width="424"/>
</tr>
<tr>
<label colspan="1" fill="both" height="57" insets="2,2,2,2" name="IP Address:" rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="424"/>
<param colspan="1" expand="true" fill="both" height="57" insets="2,2,2,2" oid="Blackstorm.IPAddress" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0" width="424"/>
</tr>
<tr>
<label colspan="1" fill="both" height="57" insets="2,2,2,2" name="Port Numbers:" rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="424"/>
<table colspan="1" fill="both" height="57" insets="2,2,2,2" rowspan="1" weightx="1.0" weighty="1.0" width="424">
<tr>
<abs colspan="1" fill="both" height="52" insets="0,2,0,2" rowspan="1" weightx="1.0" weighty="1.0" width="76">
<abs bottom="0" id="Port1" left="0" name="Port1" right="0" top="0" visible="true">
<table bottom="0" left="0" right="0" top="0">
<tr>
<label colspan="1" fill="both" name="Channel 1" rowspan="1" style="txt-align:center" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<param colspan="1" element="0" fill="both" oid="Blackstorm.PortNumber" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<abs bottom="0" id="Port2" left="0" name="Port2" right="0" top="0" visible="true">
<tr>
<label colspan="1" fill="both" name="Channel 2" rowspan="1" style="txt-align:center" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<param colspan="1" element="1" fill="both" oid="Blackstorm.PortNumber" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<abs bottom="0" id="Port3" left="0" name="Port3" right="0" top="0" visible="true">
<tr>
<label colspan="1" fill="both" name="Channel 3" rowspan="1" style="txt-align:center" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<param colspan="1" element="2" fill="both" oid="Blackstorm.PortNumber" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
<abs bottom="0" id="Port4" left="0" name="Port4" right="0" top="0" visible="true">
<tr>
<label colspan="1" fill="both" name="Channel 4" rowspan="1" style="txt-align:center" weightx="1.0" weighty="1.0"/>
</tr>
<tr>
<param colspan="1" element="3" fill="both" oid="Blackstorm.PortNumber" rowspan="1" showlabel="false" weightx="1.0" weighty="1.0"/>
</tr>
</table>
</tr>
</table>
</tr>
</table>
<abs height="87" left="1654" style="bg-u:platform:/plugin/com.rossvideo.common.oglml/patterns/ross-150.png;bg-align:center;bg-fill:shrink;" top="11" virtualheight="87" virtualwidth="252" width="252"/>
<abs height="90" left="18" style="bg-u:Images/BlackStorm_sm.png;bg-align:center;bg-fill:none;" top="11" virtualheight="90" virtualwidth="333" width="333"/>
<table height="962" id="Table Test" left="959" top="101" width="946">
<tr>
<abs colspan="1" fill="both" height="253" id="" insets="2,0,2,0" name="" rowspan="1" style="bg#panelbg;bdr:etched;" virtualheight="237" virtualwidth="946" visible="false" weightx="1.0" weighty="1.0" width="946">
<table height="59" left="26" top="19" width="897">
<tr>
<label colspan="1" fill="both" height="90" id="" insets="2,2,2,2" name="" rowspan="1" style="txt-align:center;" weightx="1.0" weighty="1.0" width="184"/>
</tr>
</table>
<abs bottom="0" colspan="1" fill="both" id="Channel1" left="0" name="" right="0" rowspan="1" style="bg#panelbg;bdr:etched;" top="0" virtualheight="224" virtualwidth="847" visible="false" weightx="1.0" weighty="1.0">
<table height="86" left="14" top="12" width="817">
<tr>
<label colspan="1" fill="both" height="90" insets="2,0,2,0" name="Channel 1: " rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
<label colspan="1" fill="both" height="90" id="clipName1" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
<tr>
<label colspan="1" fill="both" height="90" insets="2,0,2,0" name="Status: " rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
<label colspan="1" fill="both" height="90" id="status1" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
</table>
<table height="107" left="14" top="104" width="811">
<tr>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgCueClip.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['CueClip']%
cueClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgRewind.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['RewindClip']%
revClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgStop.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['StopClip']%
stopClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgPlay.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['PlayClip']%
playClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgPause.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['PauseClip']%
pauseClip(1);</task>
</button>
<button buttontype="push" colspan="1" fill="both" height="92" name="" rowspan="1" style="bg-u:Images/lgFastForward.png;bg#dark;i-u:;" weightx="1.0" weighty="1.0" width="92">
<task tasktype="ogscript">%const['GlobalScripts']['FastForwardClip']%
ffClip(1);</task>
</button>
</tr>
</table>
</tr>
<tr>
<tr>
</tr>
</table>
<abs bottom="0" colspan="1" fill="both" id="Channel2" left="0" name="" right="0" rowspan="1" style="bg#panelbg;bdr:etched;" top="0" virtualheight="224" virtualwidth="847" visible="false" weightx="1.0" weighty="1.0">
<tr>
<label colspan="1" fill="both" height="90" insets="2,0,2,0" name="Channel 2: " rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
<label colspan="1" fill="both" height="90" id="clipName2" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
<tr>
<label colspan="1" fill="both" height="90" id="status2" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
</table>
<tr>
cueClip(2);</task>
</button>
revClip(2);</task>
</button>
stopClip(2);</task>
</button>
playClip(2);</task>
</button>
pauseClip(2);</task>
</button>
ffClip(2);</task>
</button>
</tr>
</table>
</tr>
<tr>
<tr>
</tr>
</table>
<abs bottom="0" colspan="1" fill="both" id="Channel3" left="0" name="" right="0" rowspan="1" style="bg#panelbg;bdr:etched;" top="0" virtualheight="224" virtualwidth="847" visible="false" weightx="1.0" weighty="1.0">
<tr>
<label colspan="1" fill="both" height="90" insets="2,0,2,0" name="Channel 3: " rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
<label colspan="1" fill="both" height="90" id="clipName3" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
<tr>
<label colspan="1" fill="both" height="90" id="status3" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
</table>
<tr>
cueClip(3);</task>
</button>
revClip(3);</task>
</button>
stopClip(3);</task>
</button>
playClip(3);</task>
</button>
pauseClip(3);</task>
</button>
ffClip(3);</task>
</button>
</tr>
</table>
</tr>
<tr>
<tr>
</tr>
</table>
<abs bottom="0" colspan="1" fill="both" id="Channel4" left="0" name="" right="0" rowspan="1" style="bg#panelbg;bdr:etched;" top="0" virtualheight="224" virtualwidth="847" visible="false" weightx="1.0" weighty="1.0">
<tr>
<label colspan="1" fill="both" height="90" insets="2,0,2,0" name="Channel 4: " rowspan="1" style="style:TitleLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
<label colspan="1" fill="both" height="90" id="clipName4" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
<tr>
<label colspan="1" fill="both" height="90" id="status4" insets="2,2,2,2" name="" rowspan="1" style="style:ParamLabel;txt-align:center;" weightx="1.0" weighty="1.0" width="170"/>
</tr>
</table>
<tr>
cueClip(4);</task>
</button>
revClip(4);</task>
</button>
stopClip(4);</task>
</button>
playClip(4);</task>
</button>
pauseClip(4);</task>
</button>
ffClip(4);</task>
</button>
</tr>
</table>
</tr>
</table>
João victhor Mariano
Sent: 11-09-2023 10:37
Subject: VDCP custom panel - Dashboard
Hi João,
Thanks for reaching out! Unfortunately, you cannot upload grid files to the DashBoard Community forum, I would recommend renaming the file and changing its extension to ".txt" or sharing the link of your custom panel hosted on Google Drive or One Drive. I look forward to finding a solution for you.
Cheers
Altaz Daruwala
