Grayed out option.
Total dick tease.
Sent: 04-25-2024 13:54
Subject: Virtual output question
In XPression Designer & Developer, full screen virtual outputs are not supported.
You need to upgrade to XPression Studio, BlueBox or Prime for full screen virtual outputs.
Sent: 04-25-2024 12:40
I'm on version 11. I have the 'right click' option but as Azathoth pointed out, it's greyed out. What I want is to fill the entire window and not have all that white space
Donny Swanson
Graphic Designer, Broadcast
TVO (TVOntario)
Toronto Canada
Sent: 04-25-2024 09:40
There are two ways to make a Virtual Output fullscreen.
When you create one, there is the option to check the "FullScreen" tickbox:
When you already have a Virtual Output, you can right-click in it to make it fullscreen:
Rob van Rooyen
Senior Graphics Specialis
NEP The Netherlands
Hilversum Netherlands
Sent: 04-24-2024 16:10
Hi All,
I'm wondering if there's a way to make the size of the virtual outputs use it's entire window. There's so much white space that could be used (see screen shot) and it seems like a waste. I see that it's a 1920x1080 resolution but can it be zoomed in through a setting that I haven't found? I don't want to change my monitors scale or resolution and I don't think that would fix the 'issue' anyways. Thanks in advance...
Donny Swanson
TVO (TVOntario)
Toronto Canada
