have you tested by putting in a data you know is the the data rather than the macro?
Sent: 09-12-2023 13:51
Subject: Visual Logic and Datalinq
So i seem to still be strugggling. sorry. thank you for the help. here is my query in the table line:
SELECT [Code] FROM [Exit_Code_List] WHERE [Date] = "@DATEHERE@"
in the spreadsheet the columns are"Code"and"Date"
currently i have the DATEHERE text object visible in the scene for reference the date is showing correctly. It shows 9/11/2023 and the sheet has a date of 9/11/2023 but the code for that date is not reflecting.
Chad Loury
AZUSA PACIFIC UNIVERSITY
Sent: 09-11-2023 14:26
You don't need visual logic, you can just do what you need directly on the text object under the data tab and just click datalinq.
You probably need quotes like in my example around @textobject@ because date will be a string not an integer.
Sent: 09-11-2023 13:53
Thank you, this is what i was looking for. yet im still struggling with my outcome. Here is my querey and yet not sure what i have wrong.
Chad Loury
Sent: 09-11-2023 04:54
Make a text object for the date and then connect that to a date widget.
When you connect to datalink just use a query for the connection that looks at that text object.
