Edit: [SOLVED] See my reply.
Greetings all -
Looking for guidance on how I can achieve the following: a 5-on-4, 4-on-4, etc., powerplay is over (Hockey), so the powerplay slider animates out (i.e., slides back underneath the main score bug) via a Scene Director being triggered with visual logic (reading data from an AllSport CG, determining the conditions are not true for a non-standard single player powerplay).
Here is the issue I am running into: my 5-on-4, 4-on-4, etc., powerplay graphic uses the same background and are contained within the same AnimationController. I simply use visual logic to hide/unhide the text layers that say "5 on 4" or "4 on 4", etc., based on conditions. HOWEVER, when the conditions are not true, I use visual logic to trigger the "powerplay OUT" Scene Director to play - this is where the issue is. Because of the fact that the conditions are not true, all the text disappears (is hidden) before the background is finished animating out.
Is there a way to tell what text last had the visibility toggled ON? So that when the Scene director is triggered, I can replace with that string (i.e. "4 on 4" etc.) so that it looks like the text is still sliding out with the background? Or do you have any other possible solutions?
Many many thanks!
I hope I'm being clear on what I need help with. I've attached the VL to this post.
Elias Kutz
Broadcast Engineer
Bethany Lutheran College
