That fixed it! Thanks.
Sent: 08-14-2023 11:04
Subject: Visual Logic is gone?
Hi Matthew
We have investigated the issue and found a problem with one of the Visual Logic definition files when used on Mac OS. This but impacts users who add Acuity APIs to their Custom Panels on a Mac. The fastest way to restore your Visual Logic functionality will be to remove the "_Acuity.xml" file from DashBoard/VisualLanguage/blocks. This file is not necessary for any Acuity RossTalk APIs you may be using in your panels and its removal should work around the bug until a more permanent solution can be completed by the DashBoard team.
Cheers
James
James Peltzer
Sent: 08-08-2023 16:28
Oh sorry. I thought I had attached that. I've got 2 panels here. V1 is stable and working. I've starting reworking it to add more functionality in V2, which is where I made the discovery. But neither are showing visual logic anymore.
Matthew Drury
Systems Engineer
North Point Ministries
Alpharetta United States
Sent: 08-08-2023 11:07
Hi Matthew
Sorry for the very long delay in response. We would still like to take a look at the problematic Custom Panel if you have it available. It does not appear to have been attached to your response.
Cheers
James
James Peltzer
Sent: 04-11-2023 13:02
It was definitely made in version 9, but I'm not sure which revision. I am seeing Visual Logic show up in new blank panels. And I understand that some of my button actions might have been broken because I copy-pasted code. But I can't even see Visual Logic in brand new buttons on this custom panel. I've attached it for reference.
Matthew Drury
Systems Engineer
Sent: 04-10-2023 11:35
Hi Matthew
What was the previous version of DashBoard that you were using to create the panel? If it was a much older version, it is possible that the block ID structure might have changed and this could impact Panel Builder's ability to re-create your existing blocks. If it was a recent version, we might want you to send us your panel for a closer look.
James Peltzer
