  • 1.  Visual Logic or Scripting to change text object Y position
    Posted 10-16-2023 16:46
    I have 2 text objects, one above the other. I want the top text object to move down slightly if the there is nothing typed in the 2nd text object.
    I know this should be very simple. But no matter what I try in Visual Logic, the top text object just moves to a set position in the center of the screen, whether there is text typed in the 2nd object or not.
    I am using XPression v6.5.
    Thanks in advance.
    Cindy McNicholl
  • 2.  RE: Visual Logic or Scripting to change text object Y position
    Ross Staff
    Posted 10-16-2023 16:51
    What logic blocks are you using?
  • 3.  RE: Visual Logic or Scripting to change text object Y position
    Posted 10-16-2023 17:06
    The top text object is called TITLE; the one below is called SUBTITLE.
    I have used [SUBTITLE length]   [Smaller Than 1]   [TITLE Position.Y]  .... then tried to ADD or OFFSET the Value
    Cindy McNicholl
  • 4.  RE: Visual Logic or Scripting to change text object Y position
    Ross Staff
    Posted 10-16-2023 17:10
    here's one option for you;
