I am using a Switch block in Visual Logic to trigger some custom functions that I've set up in the API. The code fails because of missing semi-colons that the visual logic seems to fail to include, only for my custom code calls though. I can add them manually but I really don't want to break the visual logic function. First section of code is VL tied to my button. Second section is the custom function.
switch (params.getValue('dayPart', 0))
case 0:
if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),00,00,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),09,00,0,0).getTime()) { takeTess1(100001) takeTess2(200001) ogscript.debug("test h");
} else { } if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),09,01,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),12,00,0,0).getTime()) { takeTess1(100002) takeTess2(200002) ogscript.debug("test g");
} else { } if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),12,01,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),15,00,0,0).getTime()) { takeTess1(100003) takeTess2(200003) ogscript.debug("test f");
} else { } if (new Date().getTime() > new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),15,01,0,0).getTime() && new Date().getTime() < new Date(new Date().getFullYear(),new Date().getMonth(),new Date().getDate(),23,59,0,0).getTime()) { takeTess1(100004) takeTess2(200004) ogscript.debug("test e");
} else { } break;
case 1:
takeTess1(100001) takeTess2(200001) ogscript.debug("test d");
break;
case 2:
takeTess1(100002) takeTess2(200002) ogscript.debug("test c");
break;
case 3:
takeTess1(100003) takeTess2(200003) break;
case 4:
takeTess1(100004) takeTess2(200004) ogscript.debug("test a");
ogscript.debug("test b");
break;
<api>
function takeTess1(takeID1) {
/*-arg takeID1: { "type": "STRING", "widget": "text", "value": "123456"} -*/
/*! block id=1110 !*/
rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'tessera1.host'), parseInt(ogscript.getPrivateString('hosts', 'tessera1.port')), 'TAKE ' + takeID1);
/*! block id=1115 !*/
ogscript.debug("Tess 1 Take " + takeID1);
<block id="1110" type="customcode" x="10" y="10" w="971" CODE="rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'tessera1.host'), parseInt(ogscript.getPrivateString('hosts', 'tessera1.port')), 'TAKE ' + takeID1);" />
<block id="1115" type="customcode" x="10" y="174" w="343" CODE="ogscript.debug(&amp;quot;Tess 1 Take &amp;quot; + takeID1);" />
Joshua Coats
Newsroom Artist Supervisor
Scripps News
Atlanta United States
