I'm trying to use Visual Logic in my Xpression version 7.0. My goal is to make the scene "visible" and "play animation" when the formatted timer in text hits 00:59 until it counts down to 00:00. It should be visible until I manually reset the timer and play ONCE during 00:59. I have limited nodes so I used the String Compare (Equal) with String Value (00:59) then out to the Counter node before the Visible and Play node. Please see photo
FYI, hope this will help you: https://youtu.be/-Zrcty4Oizk?t=278
Thank you! I will look into this..
62 Auriga DriveNepean, OntarioCanada, K2E 7W6
Phone+1 613 228-0688Emailcommunity@rossvideo.com
LoginJoinHelp/FAQEventsrossvideo.com
Terms and ConditionsPrivacy PolicyDMCA Policy
