Connectivity
  • 1.  VITC distribution in Ultrix?
    Posted 05-03-2023 17:01
    I honestly don't know if this is a thing, so forgive my ignorance. I have bars/tone coming off our SRG-2200 master sync generator into my Ultrix. This SDI signal carries our house clock timecode via VITC. If i route this test signal to my record decks they will sync up and read out this timecode data. But if I route any other feed, say a Program Feed that i want to record, this does not have the VITC data on it. Is there a way that VITC can be distributed/embedded to other outputs on the router so I can sync up all my record decks like this? FYI, the decks do not have external LTC inputs. Thanks for any insight you can give!
    Will Compton
    Technical Director
    NorthStar Church
  • 2.  RE: VITC distribution in Ultrix?
    Posted 05-05-2023 09:45
    Hi Will,
    Unfortunately this is not possible to do directly with ultrix routes. You would need to route the desired signal through an external VITC insertion card and then bring the signal back into the ultrix.
    Mike Pomerleau
