Yes, the number 0 is the section I'm trying to change. It's showing that because the layer was set to datalinq in the sequence. Typically, when working properly, it should say the team name and then score after a set is updated. In this instance, since I have the sets as 25-12, 25-10, 7-25, and 6-25, it should say "Tied 2-2." I am making progress. I did figure out that the visual logic was disabled. I turned on the check box, and now the visual logic all seems to be working properly. I feel incredibly silly that I couldn't see that in the first place. I guess another set of eyes was needed. Thank you for the help!
David Schuyler
Sports Producer
SCCTV
Sent: 10-29-2024 10:21
Subject: Volleyball Match Score Xpression/Dashboard
Ah, ok.
It's possible to disable a tab in Visual Logic - there is an Enabled check box at the bottom of the page under its name, could make sure that is checked.
You could also check the Datalinq connections within Visual Logic. If you click on them, a properties box appears at the bottom. Click on the 3 ... and then Browse button. If you have red text for the column and row at the top of the screen, then it can't find that connection for some reason.
I'd start with the Datalinq block top right that feeds the Input selector.
Is the number zero underneath the Set 5 on the graphic the number you are expecting to change?
Simon Latus
Simon Latus Media Ltd
United Kingdom
Sent: 10-29-2024 09:52
Yes to all of this - There are other graphics that link between Dashboard and Xpression correctly. It's the Volleyball bug that specifically has issues. We have done Football and Soccer games with the connection between Dashboard and Xpression having no issues.
David Schuyler
Sports Producer
SCCTV
Sent: 10-29-2024 06:50
Hi David
Do you have Datalinq running? That is the application that sits between Dashboard and XPression and feeds data through.
If you start Datalinq (probably a link on your desktop) then File->Load Configuration the file you need is most likely within the Misc folder of the project and has a .dsc file type.
If you do have Datalinq running, was Dashboard set to run on the same PC as Xpression? Check the Datalinq app and see if it is connected to Dashboard, and that the IP address is correct.
Simon
Simon Latus
United Kingdom
