I'm having trouble getting it to work or understand how its emulating a websocket. What would the code look like to just make a web socket connection to an ip and then just print any responses to the debug console? If I can successfully get a single command and listener for a response, I should be able to figure out everything else from there. Here is a breakdown of a simple command I am trying to do by connecting to a Red v-Raptor using their RCP2. I am attaching the API in case more info is needed.
Here's the raw data that would be sent over the WebSocket connection to establish communication and send the necessary commands:
Connection Establishment
1. Initiate WebSocket Connection:
• Connect to the WebSocket server at:
ws://10.60.230.98:9998
Commands Sent
After the connection is established, the following JSON payloads are sent:
1. Send rcp_config Command
• This command configures the WebSocket session.
• Raw JSON Sent:
"type": "rcp_config",
"strings_decoded": 0,
"json_minified": 1,
"include_cacheable_flags": 0,
"encoding_type": "legacy",
"client": {
"name": "My Awesome Control App",
"version": "1.42"
• Expected Response:
(The response from the device will vary, but it typically acknowledges receipt.)
"type": "rcp_config_response",
"status": "ok"
2. Set Project Frame Rate (rcp_set)
• This command sets the project frame rate to 24 fps (24000).
• Raw JSON Sent:
"type": "rcp_set",
"id": "RCP_PARAM_PROJECT_FRAME_RATE",
"value": 60000
"type": "rcp_response",
"status": "ok"
3. Set SDI Frequency (rcp_set)
• This command sets the SDI output frequency to 60 Hz (60000).
• Raw JSON Sent:
"type": "rcp_set",
"id": "RCP_PARAM_MONITOR_FREQUENCY_SDI",
"value": 60000
"status": "ok"
Summary of Steps
1. Establish a WebSocket connection to ws://10.60.230.98:9998.
2. Send the rcp_config command to configure the session.
3. Send the rcp_set command to set the project frame rate to 24000.
4. Send the rcp_set command to set the SDI frequency to 60000.
Seth Haberman
Associate Director of Live Broadcast Video
Gateway Church
United States
Sent: 12-11-2024 08:12
Subject: Websocket via Javascript?
Yes, the VLC example is a TCP socket, but the HTTP POST works with this listener tag also in effect creating a websocket.
Richard Crutwell
Ross Video UK
Sent: 12-10-2024 13:11
Thanks for this code!
Am I understanding that the VLC listener does Websocket then but gets responses over TCP?
Seth Haberman
Gateway Church
United States
Sent: 12-06-2024 05:44
Hi Seth,
The <listener/> tag is the best way to create a persistent connection. It has the function to send and receive messages depending on the configuration. It can be run as a script but best to begin with the Dashboard inbuilt tag button and go from there.
I've included an example; it shows a listener configured for HTTP. There is a send button on the same panel that will show you how the messages to the listener are configured. This panel doesn't send back via the socket however, I've included another example of a VLC player TCP listener for this. It shows a listener but for TCP strings rather than HTTP but it also has the send via the same connection in the <api/> tag. It is a bit trickier to get working, follow the readmes, but both can demonstrate how a connection can be made and managed.
Best regards,
Richard
Richard Crutwell
Ross Video UK
Sent: 12-05-2024 14:09
This is very helpful thank you!
my last lack of understanding is how I would set up a server in terms of usage of tags?
Would I set up an HTML tag within a custom panel and remotely load the node.JS libraries that would then run on the local custom panel? I've got some programming experience, but I am having a hard time understanding how the touch panel is able to run things on itself and pull in /host various libraries.
with that web server have to have a UI or could it run in the background.
Thanks for the help!
Seth Haberman
Gateway Church
United States
Sent: 12-05-2024 10:19
Hi Seth,
I looked at the available options in Custom Panel Development Guide, one option you can use is http (used to make REST API calls). You can create your own REST API Server as proxy server (using NodeJS) which can make use of WebSockets to send commands to your device. This way you can control and get status feedback etc using REST API. You have to code your own NodeJS server or may use any other programming language to quickly create a REST API Server to fulfil your needs.
As far as I know, External API is again OgScript. I am not sure, that it can have anything beyond OgScript available commands.
http
Used to fetch content from a web server or call restful API.
Syntax
ogscript.http(URL, method, requestContentType, dataObject, includeResponse);
Parameters
212 • ogScript Reference DashBoard CustomPanel Development Guide
| Parameter | Type | Description |
| URL | String | Yes | http URL |
| Method | String | Yes | The method for the URL request, one of: GET POST HEAD OPTIONS PUT DELETE TRACE are legal, subject to protocol restrictions. |
Request Content Type | String | Yes | The content type of the request. |
| Data Object | Object | Yes | Data can be a string, byte array, XML, or JSON object |
| Include Response | Boolean | Yes | True to include response; otherwise false. |
Returns
Returns either string data or a JSON object.
Kashif Mushtaq
Senior Software Developer
Ottawa Canada
Sent: 12-04-2024 13:58
is it possible to import a JavaScript library to achieve the socket connection using the Meta or API tag?
I've been syncing a lot of time into trying to make this connection.
I'm not totally sure how the implementation of JavaScript works within this environment. Are there certain sets of functions that work within the OG script tags and then a broader set that works inside the Meta and API tags?
Seth Haberman
Gateway Church
United States
Sent: 12-02-2024 12:12
Hi Seth,
Please check the "Communication.zip" I attached to my previous message. It has communication examples.
Kashif Mushtaq
Ottawa Canada
Sent: 12-02-2024 11:55
Thank you for the info!
are you aware of what that function might look like within the Ross talk? Do you imagine that if you could get the headers correct on the TCP command with a string you could do a socket command?
The last dashboard documentation I looked at, I couldn't find the breakdown of how the TCP messages completely worked or what extras they supported.
Seth Haberman
Gateway Church
United States
Sent: 12-02-2024 11:26
Hi Seth,
Unfortunately, OgScript does not support WebSockets at the moment.
There is a way to send and receive TCP IP messages using "rosstalk", but it also does not support adding headers to request to mimic WebSockets. As I understand you are trying to communicate with a WebSocket based Server, it would require certain WebSocket related headers to be added to the request.
However, if you take a look at "rosstalk" custom panel examples, may be, you can find another way to communicate with the server.
Kashif Mushtaq
Ottawa Canada
