Writting Script to automate taking Content on/offline using TakeID's
  • 1.  Writting Script to automate taking Content on/offline using TakeID's
    Posted 12-05-2024 12:02
      |   view attached
    This is my first time scripting with Ross Xpressions and using Visual Basic. I also do not, in any regard, have a strong background in coding or scripting. I took an Into to Comp Sci class in college, where we learned the basics of Python.
    Here is what I would like to do;
    We pull live stats into Xpressiosn through our Datalinq server. Within that live XML, a part displays the game's plays with a 1.5-second delay to the real-time play. I want to write a script that reads this XML file and takes graphics live using the TakeID in our sequence. This is the script I have written so far with documentation from Microsoft; however, it does not work. The script compiles; however, it does nothing. To be completely honest I am 100% lost on this process and imagine that this script is not written even remotely correctly. Any help would be greatly appreciated!
    Sub ProcessAndTriggerScenes()
        ' Create a new XPression engine and sequencer instance
        Dim Engine As New xpEngine
        Dim Sequencer As xpSequencer
        Sequencer = Engine.Sequencer  ' Remove 'Set'
        ' Declare other variables
        Dim xmlDoc As Object
        Dim plays As Object
        Dim playNode As Object
        Dim vh As String
        Dim uni As String
        Dim action As String
        Dim shotType As String
        Dim fastRecall As String
        Dim homeAway As String
        Dim shotCode As String
        Dim takeItem As xpBaseTakeItem
        Dim success As Boolean
        ' Load XML
        xmlDoc = CreateObject("Microsoft.XMLDOM")
        xmlDoc.async = False
        xmlDoc.Load("D:\Live Games\Stats.xml") ' Update with the correct file path
        ' Check if the XML is valid
        If xmlDoc.parseError.errorCode <> 0 Then
            MsgBox ("Error loading XML: " & xmlDoc.parseError.reason)
            Exit Sub
        End If
        ' Get all play nodes
        plays = xmlDoc.SelectNodes("//play")
        ' Loop through each play node
        For Each playNode In plays
            ' Extract attributes
            vh = playNode.getAttribute("vh")
            uni = playNode.getAttribute("uni")
            action = playNode.getAttribute("action")
            shotType = playNode.getAttribute("type")
            ' Process only "GOOD" actions
            If action = "GOOD" Then
                ' Determine home or away
                If vh = "H" Then
                    homeAway = "1"
                ElseIf vh = "V" Then
                    homeAway = "2"
                Else
                    Continue For
                End If
                ' Determine shot type
                If shotType = "3PTR" Or shotType = "3POINTER" Then
                    shotCode = "3"
                Else
                    shotCode = "2"
                End If
                ' Generate Fast Recall code
                fastRecall = homeAway & shotCode & uni
                ' Access the take item using Fast Recall ID
                success = Sequencer.GetTakeItemByID(CInt(fastRecall), takeItem)
                If success And Not takeItem Is Nothing Then
                    ' Execute the take item to put it on air
                    takeItem.Execute
                    ' Wait for 3 seconds
                    PauseForSeconds (3)
                    ' Take the scene off air by executing it again (toggle off)
                    takeItem.Execute
                End If
            End If
        Next
    End Sub
    ' Function to pause execution
    Sub PauseForSeconds(ByVal seconds As Integer)
        Dim endTime As Double
        endTime = Timer + seconds
        Do While Timer < endTime
            ' Wait
        Loop
    End Sub
    Jonathan Peters
    Team Lead & Broadcast Engineer
    Forester Digital Network
    Attachment(s)
    xml
    Stats.xml   78 KB 1 version
  • 2.  RE: Writting Script to automate taking Content on/offline using TakeID's
    Posted 12-16-2024 14:29
    Can you explain what it is you want to do a bit more?
