Connectivity
  • 1.  X-Y custom panel
    Posted 01-13-2026 01:50
    I'm trying to make a custom panel to perfom X-Y crosspoint actions. Of course there are premade soft panel but the aim here is to have somthing flexible with sources and destinations I want and just a take action with only certain level preselected without to have to select it on the panel...
    So do you have an idea how to code such type of X-Y panel where I select a destination then a source then take and perfom the crosspoint for the levels delcared in the code?
    Best regards,
    Boris salhaji
    EIC
    France Télévisions
  • 2.  RE: X-Y custom panel
    Posted 02-11-2026 11:09
    Hi Boris
    This is a complicated question and I dont think i can answer it in the forum. THe short answer is yes it is possible to program a panel that does what ypou need, but you need to find the correct variables and script them into your page.
    If you reach out to technical support they can put you into contact with me and we can get a basic panel started together.
    Mike Pomerleau
