  • 1.  Xcel Spreadsheet Using Drop down Menu
    Posted 02-09-2026 11:50
    Hi Everyone,
    I'm currently experiencing an issue with an Excel spreadsheet that has a drop-down menu. I've attached the Excel sheet along with the error message I'm encountering. The original spreadsheet wasn't shareable, and I'm wondering if that's causing the problem. We need the spreadsheet open for real-time updates, but when it is open, my crawl only reads the first 5 items in a loop. However, when I exit out of the spreadsheet, my crawl works perfectly fine. Could this be related to the fact that the spreadsheet is not shareable, or is it an issue with the drop-down menus?
    Thank you for your help!
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
    Attachment(s)
    xlsx
    5452.xlsx   20 KB 1 version
  • 2.  RE: Xcel Spreadsheet Using Drop down Menu
    Posted 02-10-2026 06:25
    have you tried legacy sharing?
    https://rossvideo.community/communities/community-home/digestviewer/viewthread?GroupId=199&MID=24452&CommunityKey=91812bfd-9393-4a3f-8a74-7f8035df130e
  • 3.  RE: Xcel Spreadsheet Using Drop down Menu
    Posted 02-10-2026 10:02
    We resolved the issue. We did try the legacy option, but the problem was with the Excel sheet. Once we changed it to "Convert to Range," it worked perfectly.
    Lazaro Lopez, TV Director/Editor
    Communications, Information and Technology Department (305) 375-2432
    miamidade.gov
    Connect With Us on Twitter | Facebook | Instagram | YouTube
