Just wanted to update the thread...
Jeff's suggestion was spot on. The ability to delete map scenes was tied to the Web User Groups permissions.
Thanks,
John
John Renigar
wral
Sent: 02-21-2023 13:43
Subject: XPN MAPS
Thanks Jeff,
Great suggestion. I'll take a look at the user permissions.
Thanks,
John
John Renigar
wral
Sent: 02-21-2023 11:55
Subject: XPN MAPS
John,
Sounds like the HTML5 Client user login you're using might not have permission to delete saved scenes. Web User Groups need to be given permission to delete saved scenes, then any user assigned to that group will be able to delete in addition to duplicating.
Jeff Mayer
Sent: 02-20-2023 13:31
Subject: XPN MAPS
Thanks, Red, but we're unable to find options to delete individual user-saved maps from the EDIT SAVED SCENES section in the maps designer program. We can only load them as if we we're going to adjust parameters.
John Renigar
wral
Sent: 02-20-2023 13:02
Subject: XPN MAPS
It's been a while since I used maps but I believe you have to do it from the server or manage templates in designer.
