10.5 build 5543.
dim input as string
dim obj as xpPublishedObject
dim initial as string
engine.Sequencer.GetFocusedPublishedObject(obj)
obj.GetPropertyString(0, initial)
input = InputBox("Enter the number of the character you want to insert." & VbCrLf & VbCrLf & " 1: +" & VbCrLf & " 2: Á" & VbCrLf & " 3: á" & VbCrLf & " 4: É" & VbCrLf & " 5: é" & VbCrLf & " 6: Í" & VbCrLf & " 7: í" & VbCrLf & " 8: Ó" & VbCrLf & " 9: ó" & VbCrLf & "10: Ú" & VbCrLf & "11: ú" & VbCrLf & "12: Ü" & VbCrLf & "13: ü" & VbCrLf &"14: Ñ" & VbCrLf & "15: ñ" & VbCrLf & "16: © (Copyright)" & VbCrLf & "17: • (Circle Bullet)" & VbCrLf & "18: ½ (One Half)" & VbCrLf & "19: ¼ (One Quarter)" & VbCrLf & "20: ⅓ (One Third)" & VbCrLf & "21: ⅔ (Two Thirds)","Insert Special Character","")
if input = 1 then
obj.SetPropertyString(0, initial + "+")
else if input = 2 then
obj.SetPropertyString(0, initial + "Á")
else if input = 3 then
obj.SetPropertyString(0, initial + "á")
else if input = 4 then
obj.SetPropertyString(0, initial + "É")
else if input = 5 then
obj.SetPropertyString(0, initial + "é")
else if input = 6 then
obj.SetPropertyString(0, initial + "Í")
else if input = 7 then
obj.SetPropertyString(0, initial + "í")
else if input = 8 then
obj.SetPropertyString(0, initial + "Ó")
else if input = 9 then
obj.SetPropertyString(0, initial + "ó")
else if input = 10 then
obj.SetPropertyString(0, initial + "Ú")
else if input = 11 then
obj.SetPropertyString(0, initial + "ú")
else if input = 12 then
obj.SetPropertyString(0, initial + "Ü")
else if input = 13 then
obj.SetPropertyString(0, initial + "ü")
else if input = 14 then
obj.SetPropertyString(0, initial + "Ñ")
else if input = 15 then
obj.SetPropertyString(0, initial + "ñ")
else if input = 16 then
obj.SetPropertyString(0, initial + "©")
else if input = 17 then
obj.SetPropertyString(0, initial + "•")
else if input = 18 then
obj.SetPropertyString(0, initial + "½")
else if input = 19 then
obj.SetPropertyString(0, initial + "¼")
else if input = 20 then
obj.SetPropertyString(0, initial + "⅓")
else if input = 21 then
obj.SetPropertyString(0, initial + "⅔")
else if input = "" then
else
MsgBox("Invalid input.",0,"Insert Special Character")
end if
Jack Reynolds
Sent: 09-27-2023 16:15
Subject: xpPublishedObject.SetPropertyString Cursor Setpoint
Can you provide your version, build and a sample script that has this problem?
