I would probably script it but I think you might be able to skip to the part of the scene director that's relevant for your date using the date and time blocks in Visual Logic.
So if the date = 7/8, director.position = 120 or whatever you needed to do.
Only issue with doing it in VL is it might force the scene director to always be at that position rather than continue to play you may need to test that.
Sent: 03-08-2024 12:16
Subject: Xpression and Datalinq
I've attached how I did my visual logic as well. It works when I do that, but I see a empty space when I run the group. I tried the <n> method but that didn't work. I think it's because I'm using scene directors. I see the empty space then the next meetings animate in. I don't want to see the empty space and I just want it to go on to the next meeting.
Thank you for all your help.
Lazaro Lopez, TV Director/Editor
Communications and Customer Experience Department(305) 375-2432
miamidade.gov
Connect With Us on Twitter | Facebook | Instagram | YouTube
Sent: 3/8/2024 11:16:00 AM
Subject: RE: Xpression and Datalinq
So are all the ones with the different up coming dates in each of those or is each on of those a different upcoming event / date?
Sent: 03-08-2024 11:14
Sent: 3/8/2024 11:03:00 AM
Is it all one scene director?
