No they are just the defaults and I hadn't changed them to get this result.
Btw with the video mask you can just right click, add mask > video and if the video has alpha channel it will work as a mask.
Just be sure the original video has an alpha channel and when you use whatever encoder, either XPression Video Coder or your own choice you encode (RGB+A) as you rightly mentioned above.
Sent: 09-01-2022 19:07
Subject: XPression and Masks - I would like an answer from a ROSS Employee
Ok, I got to the same conclusions and results, just a tad different way about it appereantly.
But thank you Red.
Second, I got to ask you now, I see you have also checked the two options for "No Depthwrites" and "Ignore Object Alpha".
Any reason for that in this case? Or any reason for it in particular?
Aleksander Stalsberg
Norway
Sent: 09-01-2022 18:47
1. Yes, add an image or video mask and then change the alpha current stage to invert.
2. Yes add another layer with that image.
Exactly the same can be done with videos.
