NO I did try it, I don't know what I am doing wrong.
however I did it may way, the input text i split anytime you hit enter, so it dos not count the character, I think is more ok like this:
I put the script on the scene events and in the text events and it worked
' Declare variables to reference the text boxes
dim Text_Input as xpTextObject
dim Text_Output_1 as xpTextObject
dim Text_Output_2 as xpTextObject
dim Text_Output_3 as xpTextObject
' Get references to the text boxes
Self.GetObjectByName("Text_Input", Text_Input)
Self.GetObjectByName("Text_Output_1", Text_Output_1)
Self.GetObjectByName("Text_Output_2", Text_Output_2)
Self.GetObjectByName("Text_Output_3", Text_Output_3)
' Split the input text by lines
dim lines() as string
lines = Split(Text_Input.Text, vbCrLf)
' Assign each line to a different text box
if UBound(lines) >= 0 then
Text_Output_1.Text = lines(0)
else
Text_Output_1.Text = ""
end if
if UBound(lines) >= 1 then
Text_Output_2.Text = lines(1)
else
Text_Output_2.Text = ""
end if
if UBound(lines) >= 2 then
Text_Output_3.Text = lines(2)
else
Text_Output_3.Text = ""
end if
Gerond Taci
Graphic motion designer
Euronews Albania
Tirana Albania
Sent: 08-22-2024 15:42
Subject: Xpression Autofollow Text
The layer names are missing the _ underscore i.e. OutText_1 to match what is in the script.
Paul
Sent: 08-22-2024 12:54
hello, thank you for the script, I am trying to implement it on xpression 8.5 but somehow it doesn't work, even the compilation is ok,
Gerond Taci
Sent: 06-05-2023 04:56
Hi Tani.
In this case you will need to create some text objects. One of them is for input text and you will need to hide it from online render (put it into a layer object with enabled property 'Render Layer in Preview Only').
Others of them are for output text with auto follows quads (the maximum amount you can be expected, for example 4) and desable on them 'Publish Object' in the 'Template Links' tab. For eache output text object create a quad with autofollow.
Then put the scrip below into the input text object 'OnSetText' tab in an 'Edit Script Events'
Dim intext() As String = Text.Split(Chr(10)) Dim outtext(3) For i As Integer = 0 To 3 scene.GetObjectByName("OutText_" + CStr(i), outtext(i)) 'output text objects named as 'OutText_0, OutText_1, OutText_2 and etc' outtext(i).Text = "" Next For i As Integer = 0 To intext.Length - 1 outtext(i).Text = intext(i) Next
Roman Yaroshenko
chief specialist
RBC-TV
Moscow Russian Federation
