I would like to add Rosstalk commands to Xpression so that each new element that plays in Xpression sends a Rosstalk command to a Ross MDK111A Logo Generator to alternately load a bug (in English) and then next load a different bug with French text. And continue toggling back and forth.
I have the MDK configured for IP Rosstalk with a port, and the Xpression GPI board/Rosstalk configured to point to the IP address(hostname) and port of the MDK.
The RossTalk messages available in the Xpression drop-down don't appear to include the command I need to trigger the MDK so I entered it manually.
MSPATH channel:0:file-name Loads a media file (file-name) from the CompactFlash® (0) into Logo channel number (channel). For example, MSPATH 4:0:Logo/Ross_LOGO.png loads the media file called Ross_LOGO.png from the Logo directory into channel 4.
It did not load the graphic.
I also tried KEYAUTO 1:keyer and KEYCUT 1:keyer
Neither command turned the bug on or off. Am I missing something? Is there a diagnostic utility that I can fire up to enter these Rosstalk commands into to send on to the MDK?
thanks,
John Walsh
