Is this than XPression output engine with an SDI card? Or a designer/developer workstation?
Do you have a Ross part number? Depending on your hardware it might not have TPM compatibly to go to Windows 11.
I expect v6 will have the same issues in Windows 11 as it will in Windows 10, but I have not tried it.
When you run v6 on Windows 10 you could/will come across:
- Material previews not working
- some scene thumbnails not working
- some dialog boxes can get stuck behind the main XPression window
- maybe encounter some UI scaling issues (make sure you run Win10/Win11 at 100% text scaling)
It usable but you will have some issues.
If you are on 6.5 build 3561 or higher, and have a matrox card, then matrox driver version 9.4.2.9297 is the newest you could use, that MIGHT (but might not) work on Windows 11.
XPression v8+ would be the oldest version of XPression you would ideally try to run on Windows 11.
XPression v11+ would be the best/supported version of XPression to use with Windows 11.
