You can also put this on a text object "OnSetText" (where 5 = number of characters from the left you want to stop at).
This will only show once you type in sequence, you won't see this is layout. It will also work for datalinq objects.
Sent: 06-09-2023 09:02
Subject: Xpression - constrain user input text?
And the expert approach! Always good to see how to do it scripted.
Sent: 6/9/2023 4:28:00 AM
Subject: RE: Xpression - constrain user input text?
Here is another way. Put the script into input text object
Dim charlist() As Char = {" ", Chr(10), Chr(13), Chr(9)} Text = Text.Trim(charlist)
Roman Yaroshenko
chief specialist
RBC-TV
Moscow Russian Federation
Sent: 06-08-2023 10:45
Yes, so easy! Just set a hard limit of 5 characters. It'd been so long I forgot that was there. Thanks!
Bob Woodhead
Johns Creek United States
Sent: 06-08-2023 10:22
Just guessing here. I doubt that you can prevent a line return from being in a text box. If you want it to be free to type whatever into that box, a line return is a character that can be typed.
On the character limit. That is an option on layout side to select to max a maximum number of characters available in a text box. - https://youtu.be/qnU0C09avdU
Garrett Hall
Overtime Elite
