  • 1.  Xpression continuous animation
    Posted 01-25-2024 13:40
    Hi, I'm fairly new to Xpression and I have a question regarding a continuous animation for a flare on a lower third. The issue is that the lower third animates in over 20 frames and then I want a flare to start at the edge of the lower third separator but when I take the font on air, the flare begins halfway down the separator and I'm not sure how to get the flare to start at the exact spot I want. Any help is appreciated.
    Cheers, Katrina
    Katrina Spangler
    Student
    Assiniboine Community College
  • 2.  RE: Xpression continuous animation
    Posted 01-25-2024 14:29
    You can keyframe if a continue animation is active or not so you could keyframe in active and then activate it once the lower third is in place.
