Xpression Crawl Glitch in Logo
  • 1.  Xpression Crawl Glitch in Logo
    Posted 04-15-2024 13:11
    I created a crawl in xpression. i have the text datalinq to a microsoft exel sheet. i'm using the N method. Also i have in each scene a visual logic which is...if text 1 is empty no logo visible.
    Everything works fine but when i don't have any text in text 1 for my first scene and i play the scene i get a glitch . i see my logo appear then disappear as the crawl reads the 2nd scene. any ideas? thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 2.  RE: Xpression Crawl Glitch in Logo
    Posted 04-15-2024 14:17
      |   view attached
    i posted the video below of what its doing.
    thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 3.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 06:24
    Use an onOnline script to hide the logo instead of visual logic.
    dim text as xpTextObject
    dim logo as xpBaseObject
    self.GetObjectByName("Text1", text)
    self.GetObjectByName("Logo1", logo)
    if text.Text = ""
    logo.Visible = false
    else
    logo.Visible = true
    end if
  • 4.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 06:41
    Thank you.  I will try this when I get to work
  • 5.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 14:47
    Do I type this in its own line in the script editor?
  • 6.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 19:15
    Needs to go in onOnline.
  • 7.  RE: Xpression Crawl Glitch in Logo
    Posted 04-16-2024 21:41
    Yes I know that but do I put it all together or alin separrr lines when I type it
  • 8.  RE: Xpression Crawl Glitch in Logo
    Posted 04-17-2024 05:09
    As it's written.
  • 9.  RE: Xpression Crawl Glitch in Logo
    Posted 04-19-2024 16:21
    i typed it in as you wrote it and nothing. i typed it in Online.i still get the glitch of the logo. i think our xpression is having issues. it works well sometimes then goes bad playing the glitch. it never did that before. i did another exel sheet thinking maybe the old one was corrupt and it worked fine then started glicthing again.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 10.  RE: Xpression Crawl Glitch in Logo
    Posted 04-20-2024 01:25
    If you haven't already, could you try, in the Scene Manager, to turn off that logo object (the "eyeball") ?  That way it only is made visible once, when the script (or your previous visual logic) runs.
    Paul
  • 11.  RE: Xpression Crawl Glitch in Logo
    Posted 04-20-2024 14:42
    I'll try I check it on Monday  and see. I will let you know. Thank you.
    Lazaro Lopez
    TV/DIRECTOR/EDITOR
    MIAMI DADE COUNTY
  • 12.  RE: Xpression Crawl Glitch in Logo
    Posted 04-20-2024 11:44
    Do you know how to script and debug and use debug monitor?
    Because you need to take the example script I gave you and adjust it for your scene, like what are your scene objects called and things like that.
