Good morning,
What version of XPression are you running?
In v10.5 and higher, there is a ShowInTemplateData Visual Logic Block that will allow you to hide published objects in the Sequence or XPression Plugin
If your color choices are fixed, you could also set the Hex Code in Visual Logic without using the 2nd column. The following example is using the new String Match and String Selector blocks in 11.5 and higher, but you could also do the same thing using a combination of String Compare and Input Selector blocks in 11.0 and lower
Jeff Mayer
