Sounds familiar to a problem on another broadcast system.
Scripting fails if you do not "Run as Administrator".
Different software, same problem. ???
Launch software with a right click to get a menu and the Administrator option.
Azathoth
Son of Cthulhu
Sent: 05-06-2024 14:57
Subject: XPression GO! Scripting
Hi there,
I am working for another production outside of my main job. I have been asked to build a show on a brand new XPression GO! unit. I normally work on an XPression Studio v10.
While building this new show on the XPression GO! I attempted to use script edit on a few elements. I write my scripting but when I go to compile it, 2 errors pop up; one is an XPression error about memory, the 2nd is an error about being unable to write a file.
Is there something about the GO! that would prevent me from scripting? I thought if it was not an installed option it would have been greyed out and I wouldn't even be able to get to a point were I am writing the script.
Or, is there something I need to repair or setup correctly to make my scripting work?
Any insight on this would be greatly appreciated.
Ed
