I see a TAKE command but it looks like the TAKE(3) command as in a custom control since it has fields for take ID, frame buffer and the layer. So that actually has one more field needed to fill out. I know there used to be a TAKE(1) command that only needed the takeid field but I don't see that available any longer in rosstalk.
In Companion, it is the same list as all available commands listed here:
Sending RossTalk Commands to XPression
John Kimball
Video Production
Legislative
Sent: 02-25-2025 16:30
Subject: Xpression Layer Setting with SEQI Command using StreamDeck
Is there no TAKE command? In my dashboards I use rosstalk command TAKE eg TAKE 101
