XPression 11.0_5677
If you need the install password please DM me.
It is recommended to run the same version and build of XPression software on all the components in an XPression workflow. Unknown issues can occur if you run use mismatched builds in a workflow. If you have a full XPression workflow please work with your engineering team and coordinate with Ross Tech Support if needed.
You can upgrade/downgrade just by closing the XPression software and running the installer.
Sent: 12-05-2023 14:23
Subject: XPression - Material name showing up in text fields
Can you send me a link to download the current release?
Aaron Rice
Sent: 12-05-2023 13:59
I think you're seeing this behavior we changed in 11.0 5669:
· [fixed] removed font tags from appearing at the beginning of published text fields automatically
Sent: 12-05-2023 12:37
I'm on v 11.o build 5653
Aaron Rice
Sent: 12-05-2023 10:18
What version and build of XPression are you using?
Ex. v 11.0 build 5650
