You could try Opera or Firefox if you want a known browser but they may still take resources, Slim Browser which is very similar to firefox with a lot of the features but cutdown on resource requirements.
There are even more aggressively lightweight browsers that lack the features of the common browsers, here's a list.
https://www.makeuseof.com/best-browsers-old-low-end-computers/This isn't an official list from Ross, the official comment would be don't use a browser as it will take resources from the GPU which you don't want when doing real-time as it's one of the most intensive things you can ask a computer to do. This is just me speculating you might be able to get away with a lightweight browser.
Sent: 09-26-2022 13:42
Subject: XPression performance use increases when program window is not in focus
Yes-Microsoft Edge (Chromium) with tabs.
Is there an alternative that would play better resource-wise
Koji Kameda
Broadcast Director
Bento GG LLC
Sent: 09-26-2022 10:25
As Garrett recommends its best to avoid taking resources away from rendering if possible.
Your browser choice can make a difference though, are you using Chrome with tabs open for example?
Sent: 09-26-2022 10:23
Would probably recommend to not use other applications while you have graphics on air in that machine. While I am sure that is a normal workflow for most, a web browser can request a lot of resources from a machine depending on the webpage. - You might lessen the available recourses to the web browser that your computer allows it to have. - Or have a laptop near by in order to do the web look ups that you need to do.
Garrett Hall
Overtime Elite
