Hello everyone, I have a question to ask you, so I am writing this post.
To help with understanding, I am attaching the video file, Region Mapping file that I tested, and the XPF file.
These are the test files that I created.
As you can see in the video, the test is about XPression Tessera with a size of 5120x1080.
The green box on the right of Output Channel 2 and the green box on Output Channel 3 are part of a single scene.
However, they are divided into two regions through Region Mapping and outputted separately.
In the video, the green boxes appear as a single scene, but different transition effects are applied to each divided region.
I hope that the transition effect can be applied naturally like a single scene, rather than being applied separately to each region.
I understand that different effects are applied because the output is different, but since XPression Tessera is often used for LED walls with non-standard sizes, I don't understand why transition effects are applied separately just because the output is different.
Dong-Geun Han
Youngdo B&C
Seoul, Republic of Korea
