I still can't get the CUE command to work. I used the TypeInCmd function as you advised, but it does not work.
Anyway, we have made a workaround, by having the graphics op manually cue things by hitting "." on the numpad, but I'd like to add it to the switcher macros. Nonetheless, I'm super thankful for everyone's help, because we got this graphic to a usable state.
Ended up there were a plethora of mistakes. When I made the XPression graphic I forgot that the Scene's Datalinq connections were made to reference an Excel file that I later scrapped, so I had to change all of those links. I also never realized that the graphic designer here, for reasons unbeknownst to me, created the .psd files at 8K, so there were numerous enormous files in the scene. I also went back and changed all of the .psd files to .png files.
Although we still have a slight delay sometimes, we can at least use the graphic in our show. The delay is typically the first time we Take/Cue the graphic or after a long time of not using it. I think it must be because it has to load it into the PC's cache. Even though we are dealing with 9 players' pictures (all small .png files), 1 background image (another .png at 1920x1080), and 9 player names and 9 player number Datalinq connections, it seems that XPression should be able to handle this without any delay, so maybe there is still some troubleshooting I need to do. There is also Visual Logic on each of the 9 players' info (names/numbers), concatenating them into the corresponding player's text field. Hopefully, I find the problem in one of these components.
Roger Heyward
Sent: 04-01-2024 17:44
Subject: Xpression says Preparing and there is a delay before my graphics Take Online
You can use the TypeInCmd to type in RossTalk commands that aren't included in the listed set.
What happens if you remove all your PSD files from scene? Does it go online faster?
Sent: 04-01-2024 14:41
I can't seem to find Cue in RossTalk in my switcher commands. I am using a Vision switcher. The options I have are: SeqIn, Take, SeqOut, ClearFB, ClearLayer, ResumeLayer, ResumeFB, ClearAllFB, Read, Next, Up, Down, Focus, GPI, Trigger, TypeInCmd.
27 objects, bc there are 9 local urls for player pics, 9 for player names, and 9 for player numbers.
Roger Heyward
Sent: 04-01-2024 11:17
How many Datalinq'd text objects are in the scene?
Here's the RossTalk Command:
| CUE takeid:buffer:layer |
Prepares take item takeid to go to air next in framebuffer number buffer on layer number layer. The take item is not taken to air, but is prepared to be taken to air without any frame delay. For example, CUE 3:2:-5 prepares to load the take item 3 into the framebuffer 3 and onto layer -5.
Sent: 04-01-2024 09:45
Actually, all my data is coming from XML file via Dashboard. Anyway, it might be that I need to use that prepare/cue technique. Do you know how to trigger this from the switcher? Is there a Rosstalk command for that?
Roger Heyward
Sent: 03-26-2024 08:38
I've noticed quite a delay within XPression when the Excel file (I presume this is where your info is coming from) is still open. So be sure to have the file closed when on air. Then there is the option to prepare/cue a scene by pressing the "." (dot) on the numerical keypad. Perhaps this solves your problem also?
Rob van Rooyen
Senior Graphics Specialis
NEP The Netherlands
Hilversum Netherlands
