Hi
thanks for this. we build it as a what you see is what you get layout - put it in a group and then suddenly layers are not where they are supposed to be whether animations are involved or if the layers are static
seems a bit odd but we sort of came up with a work-around
Greg Sherris
Instructor
Assiniboine College
Sent: 01-22-2025 14:23
Subject: Xpression scene layout issue
Xpression tries to keep things "in place" when you change the hierarchy. Watch the positions in the whole chain. Sometimes it is off in the Math.
If you have any animations already set, animations might unexpectedly change what you see.
The more you use the software you will get the feel of building stuff so that doesn't happen, but it still will.
Double check your animation positions.
Azathoth
Son of Cthulhu
