Hi Hylke,
You're welcome. Glad you were able to solve the problem and glad I could help.
Gerard de Vries
Solution Architect Live Graphics & Virtual Production
EMG / BOOST Graphics
The Netherlands
Sent: 05-24-2025 14:45
Subject: xPression scene 'preparing'
Hello Gerard,
Thanks for the help!
In the end it was an issue in a video file playing in the Scene Director.
After deleting all text and quad objects the file still was 'preparing'. I did a new render in from the video and after replacing it it was fixed.
Hylke Wolfkamp
Sent: 05-06-2025 07:20
Hi Hylke,
What I always do to 'debug' a scene which is causing poroblems: duplicate the scene to have a backup, than remove all content one by one and test when the scene starts to act normal. The last object you removed just before the scene started to behave normal, was most probably the one causing a problem. Knowing that, you can start investigating *why* that object was causing problems. But, as Azathoth already mentioned, sometimes it is just a corrupt scene. For us it fortunately doesn't happen too often, but it does happen.
Gerard de Vries
The Netherlands
Sent: 05-05-2025 10:26
From time to time I'll have scenes get corrupted.
What's crazy is you can duplicate a corrupted scene and it will be fine. Then you delete the corrupted one.
Makes no sense, but I've had to do this many times. BTW, I am on 9.5. Take this advice with caution.
Azathoth
Son of Cthulhu
