Hey John,
I went to e-mail back and saw your inbox was full. I'm just going to post my message and scripts here to make sure you get them.
For the first script (where we call the group by name):
Yes, you can absolutely copy and paste the script, and alter the group name. Just change the string between the quotes here:
engine.Sequencer.GetGroupByName("myTakeItemGroup", desiredGroup)
In general:
You can trigger the script via a button press using the Keyboard/GPI mapping. I used CTRL+Numpad 9, for example.
You can drag in as many script actions as you'd like to the map, and name them based on the group you're saving.
Understanding your use case better (20+ groups that need exporting), I made a version of my initial script to just get every group in the sequencer and export them. You'll still need to change the filepath and xml to csv. I've also fixed the initial script, because I noticed that it wasn't grabbing the group itself when exporting.
Best,
Flint
Flint Gleeson
Technical Support Product Prime - Xpression
Sent: 03-10-2025 16:23
Subject: Xpression Sequencer List Data Export
Thank you Simon for the thought. In this case, I would need to capture the sequencer list before I take an item on or off air. It would be in a pre-production planning situation.
John Kimball
Video Production
Legislative
Sent: 03-06-2025 07:03
The asRun logs include the data as they are taken off air, would that be useful?
