  • 1.  XPression Template Data Coding
    Posted 25 days ago
    I am attempting to pull info from my database using a couple template fields within XPression. I've been able to get it working when my Logo Code field is set to static using this coding:
    SELECT `FIRST` & "" FROM ROSTERS WHERE (`CODE`="@Logo Code@") AND `JERSEY`=0+@Jersey@
    Here's the databse:
    Here's the working template data:
    But when I change the Logo Code to DataLinq, the data no longer pulls:
    Any thoughts on what I can do to make this work? I'd like to get some scenes that default to my away/home teams for every show.
    Robert Hundley
    Chicago United States
  • 2.  RE: XPression Template Data Coding
    Posted 25 days ago
    You need to check this on your datalinqs
  • 3.  RE: XPression Template Data Coding
    Posted 25 days ago
    That did the trick. Thank you!
    Robert Hundley
  • 4.  RE: XPression Template Data Coding
    Posted 23 days ago
    no worries :)
