Thanks Garner,
Yes, I was using an output that did not correspond to the tracking channel, I was not aware of this specific feature.
Everything seems to be working correctly despite the persistent error message. I tested several settings on Lucid Track, sending the data to the XPression with or without optical calibration or unchecking certain parameters, but the message continues to pop up.
For your information, the AW-UE 150 camera's tracking is retrieved in FreeD, and I've added its calibration file to Lucid Track.
Alan LAMY
Intégrateur graphique
Paris France
Sent: 01-10-2025 11:59
Subject: XPression Tracking
Do you have images of your setup in Lucid Track?
You have correctly setup the perspective camera to receive the tracking data from the camera tracker.
The camera in a scene assigned as the Global Tracker will receive tracking data from the camera trackers when the scene is online.
In the Camera tracking tab, the first camera tracker "ch # 1", will send its tracking data to any global tracker that is on XPression output channel 1. And so on, camera tracker "ch # 2" send data to ch 2 of XPression.
