You can take it a little further and use the fighter's name as a text macro in the path. That way when you change the fighter name, it will automatically change the path to the correct headshot. The headshot file name would have to be letter for letter the same as the fighter name. It's just fun to try. One thing I would note, instead of %name% use @name@. That's a text macro instead of a Datalinq key. (edit) I see that's basically what you are trying to do. I didn't read all the responses.
Sent: 12-29-2025 06:11
Subject: Xpression - Use Datalinq with Dynamic Material
Yes, that will work. You can use either a local file path or a URL pointing to an online image. As long as the path or URL is valid and accessible, XPression can pull it in via DataLinq.
Juha Koivisto
Tampere
Finland
Sent: 12-29-2025 01:34
Will this work if I write the image path on an Excel Sheet?
I have an Excel Sheet with boxers' BIO information already datalinq to my scenes, but I would like to datalinq their headshots too.
What would you recommend?
Alejandro Galvan
LA36 LOS ANGELES TV ACCESS
Sent: 03-25-2023 10:00
Hi Omar,
what Juha wrote does the job.
You do not even need to use a text object name. If you import all the players pictures in a material group (_Image will be added) you can datalinq directly to it with the ID and put in Append the _Image as in the picture attached. Cheers Nicole
Nicole Schindeldecker
FERNSEHGRAFIK
Sent: 03-24-2023 18:10
Select the "Requery scene datalinqs on data change" option in the DataLinq properties of the Name object to read the scene's dynamic material after the datalinq value changes. That should help.
Juha Koivisto
Tampere
Finland
