  • 1.  Xpression - using position and rotation keyframe data + c4d camera
    Posted 04-01-2026 11:59
    I created a slab that has animation in it in C4D. I imported that project into AE and extracted those keyframes and pasted them into a spreadsheet to bring into Xpression and create a keyframe file to my scene director to my object. However, when I do that, the object isnt matching up with how it should animate. The position and rotation values are way off. Do I need to do anything with adding my C4D camera into my Xpression project? I tried to do that and make it my active camera in the Xpression scene but I cant see my object anymore and cant figure out where the position values need to be to see it in the scene.
    Brian Contreras
    Production Coordinator
  • 2.  RE: Xpression - using position and rotation keyframe data + c4d camera
    Posted 04-14-2026 13:30
    you may need to change some of the values to negative if they are rotating the wrong way, that's quite common.
