NDI Libraries XPression Version Implementation
XPression v10.7 build 5586 - NDI Library v5.0
XPression v10.1 build 5417 - NDI Library v4.6
XPression v9.7 build 5065 - NDI Library v4.1
XPression v8.7 build 4708 - NDI Library v3.5
XPression NDI Feature-set
- Output fill+key (v8.0+)
- Input fill (v8.0+)
- Audio 8chs (v8.7+)
- Input fill+key (v10.1+)
Sent: 09-29-2023 10:13
Subject: Xpression via NDI to vMix
Thank you so much!
Gian Delgado-Aspiazu
Rogers
Sent: 09-29-2023 09:57
Any versions that support a physical output also support NDI outputs but it will use up one of your channels so if you have a 3 channel studio it will use one of those.
