Nevermind, upon further inspection the problem was coming from After Effects during the render.
Scott Carmichael
Indiana University
Sent: 02-06-2024 01:32
Subject: Xpression Video Coder minimum size
I'm not aware of any limitations other than files can't be more than 16,000 x 16,000. I think the smallest dimension I've used would be 200x960 probably.
What is the input dimensions and the output dimensions of the file?
What is the file type and codec of the file you are converting? Ex. .MOV Quicktime Animation)
What is the version and build of Video Coder you are using? Ex. 10.5 build 5552
