2 box dve on crossover
hello need information on how to do this in the crossover link http://youtu.be/neL_40t7a_8
Hi Jose,
See this video at about the 5 min mark
http://www.rossvideo.com/production-switchers/carbonite/carbonite-u/video-tutorial-103.html
Carbonite was built off the CrossOver base so the principles are all the same (just more features including DashBoard for PC based Menu support).
There are additional Tutorials on the Carbonite U page like Memory recalls that would also be good to watch to get again a similar feel.
#CrossOver
thanks for the reply but what I mean is how do the effect of bringing the boxes to full screen and back like this in the video to attach the link
#CrossOver
Did you watch the video about Memory system?
http://www.rossvideo.com/production-switchers/carbonite/carbonite-u/video-tutorial-104.html
This will explain how to use the attribute system – CrossOver Does not have DashBoard so you will have to use the Menu system an knobs to configure all the Attributes.
You will use the Effects Dissolve Mode.
Store a memory with Effects dissolve enabled with your two box in view.
Now Store a memory also with Eff Dis enabled with your Key 2 Box off screen and the Key 1 Box Full (you can hold the Key 1 DVE Key Type button down and press the Reset button for a quick default to full screen).
recall the first memory and they will slide back to the 2 box position.
Now store a third memory with the Key 1 DVE off screen and then the Key 2 DVE Full Screen.
Now you can use the three memories to recall between Full - Back - Full in any order you like.
#CrossOver
I’m having a slight problem creating this effect on my cross over. here’s what I’ve done:
A. Created 2 box, stored with a MemAI recall (which would allow me to select different sources in each box before they go to air)
B. Created box#1 full screen with Eff Dis recall (to create that slide effect)
C. Created 2 box again with Eff Dis recall (to slide back to the 2 box screen)
my problem is that if I select a different source in Box#1 or #2 during step A, before sending it to air, the box reverts back to the original saved source during the step B & C transitions.
My instinct is to store the recall status of the keys to “no recall” when I store them for step B and C, but that hasn’t worked for me. Is there something else that I’m missing.
does that explanation even make sense?
thanks
#CrossOver
solved.
problem was on recall end, not store end. had to set everything to “memory”, not just the recall mode.
cheers
#CrossOver
