๐ŸŽ A Handy Tool for Adapting PIERO Touch Layouts
Iโ€™ve built a small utility that helps when working with PIERO Touch layouts across different screen sizes and setups.
With this tool, you can:
Convert an existing PIERO Touch layout to work at a different screen resolution
Adapt layouts that were created in windowed mode so they can be used in maximised / full-screen mode
The tool can be downloaded from here: AFM Touch Layout Converter Final.html.zip
Just open the local html file with Google Chrome.
NOTE this HTML file is self-contained. It is not an official Ross Product and does not come with any warranty.
How to use the Piero Touch Layout Rescaler
Upload your source layout XMLSelect the PIERO Touch layout you want to convert.
Select the source resolutionThis is the resolution the layout was originally built for.Use the presets or enter the values manually.
Select the target resolutionChoose the resolution you want the layout to run on.
Click Convert and DownloadA new layout XML will be downloaded, ready to use.
Known limitations
Windows onlyLayouts created on macOS / Retina displays are not supported.
Source resolution must be correctIf the source resolution is wrong, panel positions and sizes will not scale correctly.
Background images are not scaledOnly layout panels and controls are adjusted.
Minor manual tweaks may still be requiredAlways visually verify the converted layout in PIERO Touch.
